11-28-2024 02:01 AM
Hi Team,
what is difference between override mandatory and mandatory checkbox in dictionary override?
11-28-2024 04:07 AM
Override mandatory (Property) - You are informing ServiceNow that you want to override this particular property.
Mandatory checkbox (Value) - You are informing ServiceNow that you want to make any field mandatory or not mandatory.
Nikhil Bajaj
Nikhil Bajaj
ServiceNow Rising Star-2025
11-28-2024 04:33 AM
Hello @Prathamesh Cha1
Let's say we have Parent table Task & extended table Incident. Now all the fields in task table is present in incident table. Field1 in task table is a mandatory field so by default in Incident table also it is mandatory. If we want to override the mandatory thing then on clicking override mandatory will show mandatory checkbox. Uncheck the mandatory field and therefore Field1 is not mandatory in Incident table. Similarly reverse can be done.
This will override the mandatory configuration from parent table to child table.
Example:
Here cmdb_ci field if not set to mandatory in task table can be set in Incident table.
In short Override mandatory will enable the mandatory field which can further be checked/unchecked based on requirement to override the dictionary.
Hope this helps!
"If you found my answer helpful, please like and mark it as an "accepted solution". It helps others find the solution more easily and supports the community!"
Thank You
Juhi Poddar
Juhi Poddar
11-28-2024 08:29 AM
Hi @Prathamesh Cha1 ,
Mandatory Checkbox: When checked, at the dictionary level (table's base field). it will be inherited by all its child tables .
Override Mandatory Checkbox :When checked,at the Dictionary Override level (or Field Definition Override). it can be overridden for that specific table
if my response is helpful , mark the solution as helpful.
11-28-2024 08:29 AM
