when incident priority is p5 , problem priority is also same ,but need to change.
surya65
Hi Team,
i have incident priority are: 1 to 5.
problem priority are :1 to 4.
when i  cretaed the incident with priority p5, and i created the problem through incident ,and
priority of the problem is same has incident p5.
but in the problem form, under priority drop down i have 1 - 4,
soo need to change when the incident  priority is p5, when problem priority should be p4. only.
in my case its showing p5.
how can i achive this any helps,
thanks,
surya.
20 REPLIES 20
kalyan13
Hi surya,
As per my knowledge the priority field will take from task Table. so, in incident and problem table the priority choices will be same i think that is the reason it is showing p5 in problem ticket when incident is p5 .
If u want to set priority field as p4 in problem ticket when priority is p5 in incident ticket then u need to write condition.
I hope you got my point Please mark the answer as correct/helpful.
@kalyan
Similar explanation has already been shared with the author with relevant steps on how to achieve the requirement.
Please do not duplicate the response here.
Shloke
surya65
what conditions, i should apply on this.
Surya,
I have already told you step by step condition with explanations with every screenshot, have you tried that. Are you facing an issue with the instructions shared by me or stuck ?
No one will be able to imaging where are you stuck unless you share the details as I have asked you couple of times to help further.
If you are stuck then please share the details and will help you.
Shloke
surya65
in filter conditon: i saerch Source Incident.., there is no such filed .
