when problem ticket closed then related incidents close automatically
divya123
Giga Contributor
when problem ticket closed then related incidents tickets should close automatically, i write below code but that is not working, kindly help me with your suggestions. (function executeRule(current, previous /*null when async*/) { var gr =new GlideRecord('incident'); gr.addQuery('problem_id',current.sys_id); gr.query(); if(gr.next()){ gr.state= '6'; gr.close_code= Solved('Work Around'); gr.close_notes= resolved; gr.update(); } })(current, previous); Thanks
amlanpal
Hi Divya,
You need to create/modify a after Update Business rule in the Problem ('problem') table with the Conditions and script as per below screenshot. I have tested the code and is working in my instance. Would like to request you to give it a try and let me know.
For your simplicity, I'm providing the code here:
      gr.addActiveQuery(); //Cross check only active incidents
      gr.addQuery('problem_id', current.sys_id);
      while(gr.next()){
              gr.state = '6';
              gr.close_code = 'Solved (Work Around)';
              gr.close_notes = 'The incident is Resolved as the Related Problem is Closed/Resolved';
              gr.update();
      gs.addInfoMessage('The Incident'+ gr.number+' is Resolved');
I hope this helps.Please mark correct/helpful based on impact
Use this for your requirement and this will help.
if (gr.next()) {
if(current.state=='107'){
gr.state = '6';
gr.update();
//gs.addInfoMessage('The Incident'+ gr.number+' is Resolved');
hope it helped you.
Hi Amlanpal,
Only for New State yet I am unable to resolved the incident automatically.
For in progress, assainged its working
VRNR
 I want to close problem task as well (p_task)  which was created for the parent problem.may i know how can i achieve this?
ram
