Work items imported from Jira and their connection to the release
kchadwick
We are currently using the Jira integration inside of digital product release. When using this integration Jira stories are brought over as work items. I am wondering if anyone has found out how the work items are being linked to the DPR release. I have found several tables that work with the Jira integration and are being populated but I cannot find a dot walk path from work items back to the release or any other table used in the Jira integration. Any help on this matter would be great.
It looks like I have found the table I needed. This relates the two versions together (The plan version and the DPR release version). From this table I should be able to successfully find the link of work item to DPR release.
sn_devops_m2m_plan_version_software_model
This is exactly what we did. I see the table sn_devops_plan_version where the version is created. However, I do not see how this version gets connected to the DPR release or DPR version (cmdb_software_component_model). There is a release field on the sn_devops_plan_version table but it is not filled out. I am trying to find the correct path to get all work items related to a release. For example, with product enhancements there is a field on the table linking back to the release which makes it easy to query all product enhancements on a release.
