Not able to fill condition fields through ATF
06-18-2024 04:03 AM
My requirement is to set the condition fields.
Eg: Status is In Service.
I have got this KB ARTICLE
Here is the form:
here I need to set the condition as shown.
I am using following script:
The test fails with following summary:
Test failed due to JavaScript error executing step:
Shaqeel
06-18-2024 06:20 AM
It doesn't find your table. Are you sure you haven't made any spelling mistakes in there? Does the same happen if you remove the brackets?
01-11-2025 04:40 AM
Hi @Shaqeel,
I think we can add conditions using Run server side script.
Can u give the correct table? I am trying the tables present in the screenshot but not able to get any. May be this is customized table in your instance.
If you have any similar OOTB tables, pls let me know.
FYI....I was trying to add a Filter condition for 'Business Rules' under 'When to run' section tab using the below script and it is working fine.
