Best practice for site-level issues on Locations (OOB?)
Chaz_
Hi all,
I’m trying to understand the best way (ideally OOB) to manage site-level issues/notifications in FSM.
Use case:
Field engineers need to see important site conditions (e.g. H&S risks, asbestos, barriers) whenever they attend a location, on both desktop and mobile.
Requirements:
  • Notifications tied to the Location (not individual tasks)
  • Visible whenever a Work Order/WOT is created for that site (e.g. banner or related list)
  • Ability to mark conditions as resolved
  • Maintain a history/audit of all conditions
Questions:
  • Is there anything OOB that supports this?
  • If not, what’s the lowest tech-debt approach — add a related table to Location? Or use/add fields on location?
  • Any considerations for Mobile?
From what I can see, Location doesn’t natively support this, but keen to hear if others have come across this or the best way to implement.
Thanks!
Skylar_Barth
I think possibly looking at how special handling notes function.
Or a business rule that displays an info message.
SHN does work well, the only issue is that it doesn't seem to return the SHN description, and you can only push a static message. It has helped with our design though so thanks. If you know of a easy way to push the note description and it is native that would be good.
