10-27-2025 01:35 PM
From the ServiceNow documentation, I see that control attestation is to just confirm that the control is in place.
However, it seems to me at times that control attestations are made to perform the same functionality of continuous controls monitoring.
Let us take an example:
Control: Access Reviews are performed quarterly
Here, what would be the control attestation ?
1. Attest that there is a control (procedure) to perform access reviews every quarter or
2. The manager confirming that access review is complete for the specified quarter (as explained in the post: https://www.servicenow.com/community/grc-forum/how-attestation-and-indicators-are-different/m-p/3365...
Krithika
10-27-2025 08:29 PM
Hi @KrithikaV ,
These two are distinct but complementary approaches.
Control Assessment/Attestation : is a periodic survey/Assessment based process where control owners manually confirm that controls are implemented correctly - More of a Manual way
Continuous control Monitoring: Is an automated, ongoing process that uses indicators to continuously assess and validate control compliance through system data
Let's take your example:
Control: Access Reviews are performed quarterly.
1)As the control owner, every three months you will be assigned an assessment to confirm whether Access Reviews are in place or not. This is known as Control Attestation. (You can provide evidence here, but we can't fully rely on this alone.)
2)On the other side, an indicator will be set up to run every three months, which will check your AD or wherever your access logs are available to perform a review.
- If it passes, the control is compliant.
- If it fails, your control becomes non-compliant, resulting in an issue.
- You can also run this on-demand. (There are different ways to set up indicators: basic, manual or scripted.)
I tried to keep it simple here. Hope this helps, if so
Thank you,
Hemanth
Certified Technical Architect (CTA), ServiceNow MVP 2024, 2025,2026
10-27-2025 11:55 PM
Hi.
Control attestation:
you confirm that there is something to check compliance, e.g. : there is a control implemented to check if your fridge got the right temperature: Thermometer is implemented.
This is the „attest“ state.
After review you are in „monitor“ state to check if the temperature is within the correct parameters with help of your indicators and indicator tasks.
this can be done manually, with data from instance or scripted.
another thing is audit, where for example an auditor checks if the control and indicator are sufficient.
it is NOT „manually“ (attest) or „automatically“ (indicator) as other people said.
and "accepted solutions"This motivates others to take part, post solutions and find answers. Thanks! - Mat
10-28-2025 09:09 AM
We can talk all day long on this!
Simply put - Indicators are the second line of defense: make sure to monitor the status of control implementation!
@KrithikaV : Let us know what questions you have after reading all of this - Lets resolve your queries first.
Thank you,
Hemanth
11-10-2025 06:21 AM
I'd like to enlarge the terma little - and would agree with the SOC2 definition:
Attestation is the auditor’s opinion on whether the controls are suitably designed and operating effectively.
It is IMHO always in realtion to the control itself - same may be suffcient to check if a control exists whereas others only make sense if they are operated.
The 'auditor' can be internal, external or the accountable person for the control - that will be dependent on your definition.
From my point of view: for the initially mentioned case it would be insufficient to control in that you have a process to review quarterly - it needs to be controlled that it will be executed quarterly incl attestion proof.
11-04-2025 01:58 PM
Hi @Hemanth M ,
If control attestation evaluates the control - checks if access review was performed, then when the control moves to the Monitor stage - what is it expected it monitor?
Suppose, if one has not implemented continuous controls management, then they might not have set up indicator templates or indicators. In that case, what will happen in the 'Monitor' state?
Thanks in advance,
Krithika
11-04-2025 10:55 PM
I cite from training-material (GRC: IRM Implementation Participant Guide) which you also should use:
State attest: "Control Owners are assigned ... to attest that a control is implemented"
Also check this one (read about the whole lifecycle):
https://learning.servicenow.com/nowcreate?id=nc_asset&asset_id=771f64aa479a66d019dfe23c326d43e7&nc_s...
State monitor: "In monitor indicators monitor the controls status and evaluate an organizations compliance".
