07-30-2025 01:28 AM
During control attestation, I want issues created when a Control is "Not Applicable" in servicenow. I know OOTB it is via Business Rule and OOTB script include that creates issue record, when the question answer is selected "No" and it sets non compliant.
07-30-2025 12:25 PM
Thanks for the clarification.
Based on your information:
- Search for the "GRCAssessmentUtils" Script Include
and the "GRCAssessmentUtilsBase" Script Include. - You can overwrite or extend the corresponding functions of the "GRCAssessmentUtilsBase" Script in the "GRCAssessmentUtils" Script.
- Please note, that you should never change the "...Base" Script!
- A few of the functions you are looking for:
- _createAttestationIssue
- _evaluateControl: (somewhere around line 1177 coud be interesting for you)
Another way that might be easier and also work fine, is to create a
new Attestation Template and define a Choice Field with "Yes" "no" "not appliccable" where you define ony "Yes" as correct answer.
Would be great if you mark the answer as helpful and correct if I could help you out.
07-30-2025 10:18 AM
Exactly how "No" -> Non-compliant works and we expect issue to be created for "Not applicable" -> Non-compliant
