If Q1 is Yes and Q2 is No and Q3 is No then i need to display q4 with some value .
12-23-2024 09:56 PM
Hello Everyone,
If Q1 is Yes and Q2 is No and Q3 is No then i need to display q4 with some value . Like this i have 5-6 probability scenarios. i have used Client scripts. How ever few scenarios are not working and for few the Q4 value is not getting cleared. Can anyone help me on this?
Hopefully looking for possible solution, Thanks in advance.
12-23-2024 10:25 PM
Hello Asish,
Thank You for your reply, Here is the sample screenshot.
I have 6 scenarios, Like below
Yes No No
Yes Yes No
Yes Yes Yes
No No No
Yes No Yes
No Yes No
12-23-2024 11:32 PM
@irfan12 ,
Create 6 UI Policies, same as below, with your multiple conditions.
Please mark this as "correct" and "helpful" if you feel this answer helped you in anyway.
Thanks and Regards,
Ashish
12-25-2024 11:13 PM - edited 12-25-2024 11:14 PM
Hello Ashish,
Thank You for your reply, Only one UI policy is working out of 6.
Not sure what i have missed, previously also i tried at that time also its satisfying only one condition.
12-23-2024 10:11 PM
Hello @irfan12
Can you please share all the scenarios, as these scenario's maybe linked to each other and can be better handled with UI policy.
"If you found my answer helpful, please like and mark it as an "accepted solution". It helps others find the solution more easily and supports the community!"
Thank You
Juhi Poddar
Juhi Poddar
12-23-2024 10:39 PM
Below are the 6 scenarios i have
Yes No No - Public
Yes Yes No- Private
Yes Yes Yes - General
No No No - General
Yes No Yes - Public
No Yes No - Public
