Issue with Computed inherent risk
RaymundoD
Hello Everyone!!  I would like to ask if anyone knows what's wrong.  I will explain.  We created our own assessment methodology, it was working fine but later after a language change of the Ratings it's not showing the text value (Very low, low, medium, high, etc) all other configurations like color box, summing, etc. are working as usual.
The issue is that text value is not appearing in the box.
I attach evidence..
I'll appreciate any help...
Best regards
Hello @RaymundoD,
Of course! I'll guide you through this process:
1. Right-click on the field and select Configure Dictionary.
2. Navigate to the Calculated Value tab.
3. Set the Calculated field to true and ensure the Calculation script field is populated (refer to the screenshot).
Note: This solution applies to risk assessment plugin versions 17.x and above.
Let me know if you need any further assistance!
9 REPLIES 9
Hello @RaymundoD,
Thanks a lot!!  I found it, but it's not the same view (I attach evidence) I was checking the plugin we're over 18th version,
RDP
Can you try to change the view via related links - 'Advanced View'
Thanks a lot!!! It finally works!!!
Thank you so much for this solution! This worked for me.
