Need help in configuring heatmaps for advanced risk
RehaS
There is a requirement to configure heatmap for advanced risk to add to dashboard. I am relatively new to GRC module.
I saw this ServiceNow doc - https://www.servicenow.com/docs/bundle/xanadu-governance-risk-compliance/page/product/grc-risk/task/... but unable to add the widgets in the new Platform Analytics type dashboard as there is no option to add them there. I have also enabled the properties related to it.
Need help to configure this? and if its not available OOB, please let me know the steps to create (eg: what data source/table to select etc).  May I know which table is used to create heatmap for advanced risk?
@AnupriyaC is there a business case for doing the risk assessment against a sn_risk_definition? If you do your risk assessments against a risk statement (sn_risk_definition) you wont be able to use the OOTB heatmap. The heatmap isnt configured via the report builder you need to define it via UI Builder.
