O365 onedrive intergration using integration hub spoke with Policy text Redlining feature
‎06-14-2022 01:13 AM
Connection is established between O365 and SNOW but I'm unable to upload document using connect existing document present in Policy text related tab in workspace .
Please let me know if what steps I'm missing to achieve the sync bet SNOW and O365.
Policy and Compliance Management
‎08-29-2022 02:22 AM
Folder path is not visible in GRC properties and on click connect existing no window is appearing.
Let me know what step to be taken or anything any configuration is missing.
Thanks in Advance
‎09-09-2022 08:48 PM
Were you able to make progress on this? I am stuck with the same issue.
Have you configured the API permissions for the app created in Azure as per the below doc?
Set up Microsoft OneDrive spoke (servicenow.com)
Santhosh.
‎03-08-2023 11:01 AM
Need some help i am struggling to figure out the folder path and how it should be typed into the location box. C:\Users\ssss\Desktop\New folder (2) does not work. i am not able to find any documents with any examples on how it should show.
thank you
‎02-14-2024 04:33 AM
I want to auto populate folder location as GRC.
Any configuration change is required to get this achieved?
Thank you!
‎02-15-2024 09:27 AM
Please set the folder path in GRC properties
