Role required to view GRC attestation
G Balaji
What is the role required to access attestation results for a control?
sn_compliance.admin doesnt let user to view attestation result.
Thanks.
Hi Balaji,
When you are on the attestation type , eg: GRC Attestation there is a role field on the attestation type. The user with that role mentioned on the specific attestation type  should be able to assess the respective attestation. By default it's sn_compliance.user as far as i remember.
Ashik
12 REPLIES 12
Thanks, Ashik.
I shall try it out.
Is there any references to learn more about GRC? SNOW Docs isnt enough to learn GRC implementation.
Appreciate any pointers.
Thanks.
Hi Balaji,
Please update once you have tried. That would help other's in the community.
Sorry , Even I don't have any other pointers.  I refer to doc and try it out.
https://servicenow.sabacloud.com may help.
BR,
Ashik
Were you able to resolve this issue on having a user view the attestation results? We are experiencing the same access issue and the role on the attestation didn't seem to help.
Heather
