Create Knowledge Article from problem and change using knowledge checkbox
Jayashri Sonawa
As per ServiceNow OOB functionality, whenever we closed the incident while checking the knowledge check box then the knowledge article will create. but I have a requirement like Create Knowledge Article from problem and Change as well using the knowledge checkbox
need suggestions on the same.
2 ACCEPTED SOLUTIONS
abbasshaik4
Tera Sage
Hello @Jayashri Sonawa,
Please refer to the below link:
https://docs.servicenow.com/bundle/washingtondc-it-service-management/page/product/problem-managemen...
Mark my correct and helpful, if it is helpful and please hit the thumbs-up button to mark it as the correct solution.
Thanks & Regards,
Abbas Shaik
abbasshaik4
Tera Sage
Thanks & Regards,
Abbas Shaik
is it possible to create a knowledge article from change ?
