Attachment appearing in the body of case and not header
rhyannagood
I understand that this is how it functions out of the box, but I have an attachment field on one of my record producers. Whenever someone uploads an attachment through the field, it places the attachment in the body of the record producer. I also noticed that the table name has "zz_yy" attached at the beginning. Is there any configuration I can implement to ensure the image is placed in the header instead of the body of the case?
Ankur Bawiskar
@rhyannagood
yes this is OOTB but you can use custom solution.
use this link where I shared solution on how to copy the attachment present in attachment variable to the target record so that it appears in header.
Disable ZZ_YY prefix from attachment when added through record producer
Sharing the script here
1) I created Async After Insert BR on the target table of record producer
2) Script as this
a) Remove the ZZ_YY
b) Then use the Copy Attachment
	// Add your code here
	var gr = new GlideRecord("sys_attachment");
	gr.addQuery("table_name", "ZZ_YY" + current.getTableName());
	gr.addQuery("table_sys_id", current.sys_id);
	if (gr.next()) {
		gr.table_name = current.getTableName();
		gr.update();
		new global.VariableUtil().copyAttachment(gr.sys_id, current.getTableName(), current.sys_id);
})(current, previous);
Output:
1) The file added to the record
2) The file present on the attachment variable
Ankur Bawiskar
@rhyannagood
2) Script as this
a) Remove the ZZ_YY
	if (gr.next()) {
		gr.update();
Output:
It works! However I had to change it to an 'after' insert BR, as opposed to 'async.'
Its working, then not working. Also, when it works, it shows the attachment twice. Any idea on how I can fix?
@rhyannagood
it has worked for me in the past.
Please see by debugging.
