Attachment appearing in the body of case and not header
rhyannagood
I understand that this is how it functions out of the box, but I have an attachment field on one of my record producers. Whenever someone uploads an attachment through the field, it places the attachment in the body of the record producer. I also noticed that the table name has "zz_yy" attached at the beginning. Is there any configuration I can implement to ensure the image is placed in the header instead of the body of the case?
Ankur Bawiskar
@rhyannagood
yes this is OOTB but you can use custom solution.
use this link where I shared solution on how to copy the attachment present in attachment variable to the target record so that it appears in header.
Disable ZZ_YY prefix from attachment when added through record producer
Sharing the script here
1) I created Async After Insert BR on the target table of record producer
2) Script as this
a) Remove the ZZ_YY
b) Then use the Copy Attachment
	// Add your code here
	var gr = new GlideRecord("sys_attachment");
	gr.addQuery("table_name", "ZZ_YY" + current.getTableName());
	gr.addQuery("table_sys_id", current.sys_id);
	if (gr.next()) {
		gr.table_name = current.getTableName();
		gr.update();
		new global.VariableUtil().copyAttachment(gr.sys_id, current.getTableName(), current.sys_id);
})(current, previous);
Output:
1) The file added to the record
2) The file present on the attachment variable
rhyannagood
Hi Ankur,
The BR did not work! I tested and the image still populates in the body of the case:
