Email body values in flow designer
Karanpreet
Hi guys ,
 I am trying to extract value from email body which contains certain data as Name: Value pair .
in inbound actions we can get the values by email.body.name. However when i am trying to create the inbound action flow . when i create a trigger for email & then in create record action try to get the value from script .
i tried fd_data.trigger.email.body.name
however this does not works & flow gives an error.below is the screenshot for template of email body
Can someone guide me how can i dot walk in the email body in case of flow deisgners.
BartekM
Hello, I got some similar requirement. Did you find a way to work with key:value pairs in the flow designer ?
BartekM
just found that if anybody ever needs a solution for this
custom built email flow action to parse key:value pairs
https://developer.servicenow.com/connect.do#!/share/contents/8408077_parse_email_flow_action?v=2.21&...
and a community page with the solution
https://www.servicenow.com/community/itsm-articles/how-to-read-body-text-in-inbound-email-flow/ta-p/...
Good luck!
