How to bring subject person and opened for field from HR case form to HR task form
Peeyush Jaroli
Dear Community Members,
I have a requirement where I need to show Opened for and Subject Person field on HR task form.
Both the fields are available on HR case form but is there any way I can bring them to HR task form?
Peeyush Jaroli
Hi Peeyush,
please see steps below:
1) Ensure you select HR Core Scope from application picker before creating field
2) create new field on HR Task (sn_hr_core_task) form of type Reference and Referring to HR Case table (sn_hr_core_case)
3) Submit the form
4) now configure form layout of HR Task
5) Locate the fields and then bring them on form
11 REPLIES 11
please check any client script, UI policy or field level WRITE ACLs or dictionary readonly is present for those fields
Jaspal Singh
Mega Patron
Hi Peeyush,
There does not exists any parent-child relation between HR Case & HR Task as both extends Task table directly. Same is the case for RITM & Catalog task but how does it work? Catalog Task has an additional field Request item (request_item) created which references RITM. Something similar will have to be done here as well.
You can follow steps Ankur has suggested & get a field created or HR Task that is of type reference & references HR Case. This field needs to have value set when HR Task is created.
