11-30-2025 11:33 PM
11-30-2025 11:52 PM
this is a MRVS variable set on catalog form
You can use the OOTB "Add row to multi-row variable set (SP)" step
Once you add this step you can then specify which variable will have which value when ATF runs
12-14-2025 09:43 PM
@Ankur Bawiskar No, the issue was in the pop up-the add button was not clicked. So I now added a step to click UI component and then retrieved. it works now. anyways Thanks @Ankur Bawiskar for your help as always. Looking forward brother 🙂
11-30-2025 11:54 PM
Hi @sarathsr ,
Please see below, on how to set the values for MRVS.
If my response proves useful, please indicate its helpfulness by selecting " Accept as Solution" and " Helpful." This action benefits both the community and me.
