Icon/Picture in Record producer - facing issue for updating all record producers at a time
sri vijaya
Hi
we have 100+ record producers , so for icon/picture in record producer we want to update all of them at once
so created business rule and fix script
and followed this process
  • Attaching the image in any one record producer
  • Now going to sys_attachment table and copying the sys id of the above step
  • Attaching the sys id in both business rule and fix script to run
However this is working fine for us but as these are instance dependent activity as these are manual steps for each instance, so here when one record producer is moving from instance to other with other development activity/for any issue then sys id of icon is changing everytime which is image is missing everytime
so to avoid this is there any other solution to update image/icon in all record producers at a time?
@Ankur Bawiskar @Dr Atul - LNG @Chaitanya ILCR @J Siva
@Ankur Bawiskar
Here in line 18 i am adding the record producer sys id in which i am adding the picture as first step
12 REPLIES 12
@sri vijaya
is it going inside that IF at line 20?
If yes then it will work fine.
@sri vijaya
Hope you are doing good.
💡 If my response helped, please mark it as correct ✔️ and close the thread 🔒 — this helps future readers find the solution faster! 🙏
@sri vijaya
