Issue with Attached Knowledge Articles to HR Case records
01-23-2025 02:59 AM
Hi all,
When attaching a Knowledge Article to an HR Case record, the article does not get associated, and there are no entries being created in the "Knowledge Applied to Tasks" (m2m_kb_task) table.
Does anyone have any ideas on how to resolve this?
Thank you in advance.
Best regards,
Victoria
01-23-2025 06:21 AM
Is it creating a Knowledge record with the Source Task as HR case?
If yes then this OOB BR "Create m2m_kb_task record" should create a record into the m2m table
Seems the source field is getting set as empty which is causing this BR not to trigger
01-23-2025 06:35 AM
Hi @Ankur Bawiskar ,
I cannot understand your question. Where should I check if "Is it creating a Knowledge record with the Source Task as HR case?"?
Thank you again and best regards,
Victoria
01-23-2025 06:56 AM
Also your HR table is extending HR Case table right?
please check in kb_knowledge table is record got created when you click Attach button
If yes then check the Source Task field in the list layout and see if HR case gets populated or not
01-23-2025 07:37 AM
@Ankur Bawiskar , no record is created in kb_knowledge table with the Attach button. With the core tables the record gets created in the "Knowledge Applied to Tasks" (m2m_kb_task) table.
Best regards,
Victoria
01-23-2025 04:55 AM
Did you configure your extended HR table in Contextual Search Table Configuration?
Also you should have knowledge articles in the HR knowledge base
https://instanceName.service-now.com/nav_to.do?uri=cxs_context_config.do?sys_id=ff0370019f22120047a2d126c42e706f
Add your table in the related list
You will have to do something similar for workspace similar to how Case table has
