Mark HR case confidential and once its mark true then case should be visible to HR admin
aastha3
Giga Contributor
Created a check box for HR case confidential . When its checked- true then the HR case should be only visible to HR admin.
I dont want to go with ACL . Any other way to approach this?
14 REPLIES 14
why insert/update BR is required? you just want to restrict the records visibility
okay yeah will try with query BR and in when to run I have already mentioned when mark confidential is true . Also where to mention gs.hasRole(hr_admin);
It should work the other way too ->
If the mark confidential is unchecked it should  be visible to everyone.
aastha3
Giga Contributor
Its not working .
aastha3
Giga Contributor
Its not working ankur
Its not working Ankur.
