Not able to Update state of HR case (sn_hr_core_case) through script getting error as "Source descriptor is empty while recording access for table sn_hr_core_case: no thrown error Security restricted: Read operation on table 'sn_hr_core_case' from sc
swapnaja jagada
When I am trying to update state of HR case from "Awaiting Approval" to "Ready" using script it is showing error as:
Security restricted: Read operation on table 'sn_hr_core_case' from scope 'Global' was denied because the source could not be found. Please contact the application admin.
Security restricted: Read operation on table 'sn_hr_core_case' from scope 'Global' was denied. The application 'Global' must declare a cross scope access privilege. Please contact the application admin to update their access requests."
Can you please help to resolve this issue.
susmitha17
Run the same code in fix script with scope as Hr core
tried with the same still getting same error
Mitsua
Hello @swapnaja jagadale
Please try again by doing following steps:
1)Navigate to "
2)You can see there multiple records , search for the records having target scope "sn_hr_core_case" and source scope "Global" . Pick your two records.
3)Check the status of those records. If status is "requested" change it to "allowed" and save the records.
4) Run script again
Thanks!
