script is not working in the flow designer description
chandan31
While writing script in the description in flow designer   this script is not working .
var ab= fd_data.trigger.current.subject_person;
var number = fd_data.trigger.current.sys_id;
var cd= fd_data.trigger.current.subject_person.manager;
var url = '<a href="' + gs.getProperty('glide.servlet.uri') + '/esc?id=ticket&is_new_order=true&table=sn_hr_core_case_workforce_admin&sys_id>' + number + '</a>';
var test="Dear" +ab ;
var test=cd "has requested Long Term Care Leave. Review this request and select one of the options below and click Mark as complete. You can review the request by clicking '[code]'+url+'[code]'. In the tab 'Additional Details' you can find the content of the request. Under the tab 'Attachment' you can find uploaded documents, in case documents have been uploaded";
return test;
Please help , this code is not working in the scripting section .
Chandan
Ah now I see, nothing to with "flow designers description"
Anyway, how did managed to get the fd_data etc in? Did you type that manually/pasted? Because already seeing this looks like it will never work. If it is supposed to work, it should be a nice balloon or something with blue outline etc.. Now it just looks plain text.
Let me try to reproduce.
Kind regards,
Mark Roethof
10x ServiceNow MVP
LinkedIn
It should work fine when dragging/dropping from the right column:
So question is a bit what did you do?
Kind regards,
Mark Roethof
10x ServiceNow MVP
LinkedIn
