Why Client script was not working properly on HR case?
Deepika61
Hi All ,
Actually i have created one client script to make fields visible and mandatory based on other field choice selected, Actually whenever we create a case (RP) created from portal then client script working fine, but whenever i am trying to create a case from native view, then client script not working properly
Client script
On the case form after creation on the case form it will appear both the fileds
but after change one the choice value its seams to working fine
please help me to reslove this
Deepika
@Deepika61
that page won't support any client script etc
✨ Certified Technical Architect  ||  ✨ 9x ServiceNow MVP  ||  ✨ ServiceNow Community Leader
@Ankur Bawiskar is that Ui policy also not work?
Deepika61
No ui policy and no client script was working on the case creation page for to show/hide fields or for validations
Any solution for this?
Deepika
You haven't posted your full script, without all of the unnecessary highlighting or redacting if that's what that's supposed to be, or confirmed that the UI type and mandatory & display order in the script is correct as I suggested last week.
@Brad Bowman
i have made all the changes which you propose but
Basically the client script which i wrote is perfectly working once case created ,but it won't work on the case creation page
