05-05-2026 05:47 AM
Hi Team,
We would like to confirm whether Sentiment Analysis capability is available and supported within our ITSM scope in ServiceNow, or whether it is restricted to CSM / Now Assist licensing.
Specifically, we need clarification on:
- Whether sentiment analysis can be enabled for ITSM records (incidents, comments, work notes)
- Whether this capability requires CSM plugins or is part of platform AI / Now Assist entitlement
- Any licensing or configuration prerequisites
- What i understand that each plugins having its own skills (features) and any company will buy the plugins liscens based on their needs and there is nothing called buying general liscence for Servicenow without identifying which plugins are we looking for .
Please confirm so we can align with our use case and avoid incorrect plugin dependency assumptions.
05-05-2026 06:28 AM
Ahoy @rachaachour,
yes, your thinking is correct, you install a plugin to enable Now Assist as such (Now Assist Core) it is a prerequisite to have it and then plugins per modules - eg. NA for ITSM, NA for CSM, .......
So first you need this:
And then the modules:
There are dependencies, so I cannot show you Now Assist for CSM because my available instance doesn't have CSM... so first you need to have the module enabled and then you can activate the Now Assist capabilities within that module.
So on example of ITSM which is installed, these are the AI skills we can manage, for CSM you need to activate the plugin and then activate the AI skill related to CSM. It is not possible to use Now Assist ITSM for CSM Cases...
ITSM:
https://yourinstance.service-now.com/now/now-assist-admin/skill-list/1ebe4cd7a320311079f66bcf26fcda0f
CSM:
https://yourinstance.service-now.com/now/now-assist-admin/skill-list/959ec8d7a320311079f66bcf26fcda67
Also, I found this article that might be helpful for you: Now Assist for CSM - Sentiment Analysis
05-12-2026 06:20 AM
I have been working on a couple of Now Assist projects mostly ITSM only but the AI Skills were always inactive on default and must have been manually activated (you just click Activate > Next > Next > Next > Next > Save it), after activation you can configure the visibility, role restrictions etc accordingly..
05-13-2026 04:20 AM
thanks to answer my question of today asap
05-13-2026 04:17 AM
Sorry for asking many now there is a liscence for TSM Pro which includes ITSM & CSM - which features this liscence includes and does it include the Now assist liscence or not ? or the Now assist liscence is on top of it that i have to buy the core assist and ITSM plugins in order to activate all of the 17 skills of the ITSM Plugins . Thans to clarify with details and if there is a link you can share it bec may be this TSM Pro is a very basic liscence and doesnt have any relation with the Now Assist to activate the AI features for ITSM .
05-13-2026 04:35 AM
It's okay @rachaachour as long as I can help you :))
Regarding that Pro licence... I am not sure :// for that you might need somebody in ServiceNow to ask
05-13-2026 05:24 AM
Can someone from ServiceNow answer me please its very important ???
