12-09-2025 10:41 PM
Hello Team,
I have an excel sheet of group record data.I want to create one one individual ola record for each group .
My group data is as follows
| Name | Type | Line / Vendor Manager | Description | Group email | Vendors |
| FIT | incident, request, problem, change | Acer | FIT support group | fitdesk@test.com | |
| IT SERVICE DESK | incident, request, problem, change | Adobe Systems | IT SERVICE DESK group | itservice-desk@test.com |
the below is my ola conditions how it should be created
| Title | Name | Duration Type | Duration | Schedule source | Schedule | Timezone Source | Target | Type | Table | Start | Pause | When to Resume | Stop | When to Cancel | Retroactive Start | Set Start to | Retroactive Pause | SLA Breakdown Config (Assignment Group and Assign to) |
Resolution OLA | Team1-Fulfillment | User specified duration | Breached on 'Due Date' | SLA definition | 8-6 weekdays | The caller's time zone | Resolution | OLA | sc_task | Active = true | State = Closed Complete | State = Closed Incomplete OR Closed Skipped | Yes | Created | N/A | TRUE | ||
| AND Assignment group = Team1 | ||||||||||||||||||
| AND Assignment group.Vendor is Empty |
Now instead of Team1 it should replace the group name for example "FIT" is my group's name.
also in condition also it should build active true assignment group is fit like that.
I want to use transform map and create bulk ola records.
what approach i should do to get his done.
@Ankur Bawiskar any suggestions?
12-10-2025 09:05 PM
correct it will pick the due_date field present on Task table
12-10-2025 08:32 PM
User Specified Duration has particular Duration which needs to be set
when you give Duration Type = Breach on Due Date then Relative Duration works on - Task record comes up
The combination you are looking is not allowed on form
12-10-2025 08:59 PM
Yes i too found that.
@Ankur Bawiskar
if i select Duration type as breach on Due date it will automatically take the due date of the table"sc_task" due date field right no need to explicitly mention that field any where on any field?
12-10-2025 09:05 PM
