Create Request button OOTB difference between versions
janetakiyam
Hi Community,
I was just checking skipped record when upgrading from Washington DC to Yokohama version, and notied that the condition of the OOTB create request button has changed.
As you can see below, GlidePluginManager has changed from incident_management to request_management.
As this is OOTB change, I was wondering if this change should be applied (Revert to Base system) rather than keeping the current condition.
Washington DC:
current.incident_state != IncidentState.CLOSED && (gs.hasRole("itil") || (GlidePluginManager.isActive("com.snc.itsm.roles.incident_management") && gs.hasRole("sn_incident_write")))
Yokohama:
current.incident_state != IncidentState.CLOSED && (gs.hasRole("itil") || (GlidePluginManager.isActive("com.snc.itsm.roles.request_management") && gs.hasRole("sn_request_write")))
Im assuming the record coming up ask skipped record is there was potentially slight change in the record but reverted back by a developer.
Hi @Dr Atul - LNG
Thank you for your comment
What are the impacts of reverting to base system and the script condition changing from "com.snc.itsm.roles.incident_management" to "com.snc.itsm.roles.request_management"
Hi @janetakiyam
The impact could be possible (just my thoughts), as you are changing the role, and we are unsure if this script is used to call any other locations or logic. This could affect users with that role. I recommend that before you revert to the base, if possible, log a new support case and confirm with the team. Also, if you decide to revert, do so in a lower instance and thoroughly test it
