How to auto assign incident to a particular group based on few words in description
11-02-2023 01:39 AM
I want to auto assign an Incident to a group based on few words in the description field. Please let me know how I can do that. Few words such as bot, UI path, rpa , etc etc. I am trying with one word as of now, but it is not working. Please guide
11-02-2023 02:26 AM
@Renu9 It can check from your Conditon builder itself considering you are checking it on the "Description" field on the Incident form.
I have checked it myself with Case-sensitive description words, and it works!
Let me know if it works for you
11-02-2023 02:31 AM
It works for me, check the below screenshots
Assignment Rule does considers "Case-sensitive" words as well.
Also, it is a good practice to use OOB Servicenow functionality rather than scripting it.
11-02-2023 02:23 AM
Hi @Renu9
In the record producer script write below code :
var desc = producer.description.toString();
if(desc.includes('rpa')){
current.assignment_group = 'sys_id_of_group';
ServiceNow Developer
- Socrates
11-02-2023 02:32 AM
why not use assignment rule for this?
If you want to use record producer script then here is the syntax
var description = producer.variableName; // give here the variable name
if(description.indexOf('bot') > -1 || description.indexOf('UI path') > -1 || description.indexOf('rpa') > -1){
current.assignment_group = '77c9b13d1bfe205026de123edc4bcb9a';
You can also use Before insert BR and handle it without script
✨ Certified Technical Architect || ✨ 9x ServiceNow MVP || ✨ ServiceNow Community Leader
11-02-2023 03:18 AM
I have put the same script and the log is not displaying, the Incident is not getting assigned to any group.
gs.addInfoMessage("test");
