how to highlight incident in red when SLA breached to 100 %
shweta14
I have a requirement when SLA breached to 100% then incident should highlighted in Red color.
referred this link but not helpful : - https://www.servicenow.com/community/developer-forum/how-can-we-set-incident-number-in-to-orange-col...
how to achieve this?
Thank you in advance!
@shweta14  Thanks - you need to make changes to your script include, since you have multiple SLA's attached and the incident should be highlighted even if one SLA exceeds the threshold.
Update the value in the style record to:
javascript: new ElapsedSLA().getSLAPercent(current) == true;
Update the script include
var EscalateSLA = Class.create();
EscalateSLA.prototype = {
    initialize: function() {},
    getSLAPercent: function(incRef) {
        var flag = false;
        var slaPercent = '';
        var sysID = incRef.sys_id;
        var slaGR = new GlideRecord('task_sla');
        slaGR.addQuery('task', sysID);
        slaGR.query();
        while (slaGR.next()) {
            if(slaGR.business_percentage >=90){
                  flag = true;
                  return flag;
        return flag;
    type: 'EscalateSLA'
If my answer has helped with your question, please mark it as correct and helpful
Thanks!
Please use
javascript: new EscalateSLA().getSLAPercent(current) >= 90;
Hi Jaspal,
tried but not working both conditions are same
Karan Chhabra6
Hi @shweta14 ,
Do you have multiple SLA's attached to the incident record for which you're testing this, if yes - could you please share a screenshot of that?
Thanks!
Hi Karan,
There is no specific one i'm checking.Based on 100% breach checking the incident.
for example checking for this
