05-17-2024 07:46 AM
05-20-2024 04:29 AM
@linga reddy You need to retrieve those details from JIRA and pass it to on your incident record to be attached.
Is there any configuration done in referencing the incident with JIRA ID? If not, how can you differentiate which attachment to be attached to which incident (as you mentioned its from JIRA to ServiceNow).
Please mark this as helpful and accept it as a solution if this resolves your query.
Sujatha V.M.
Sujatha V.M.
05-19-2024 10:34 AM
@linga reddy You can send attachments automatically with Unito's 2-way integration for Jira + ServiceNow automatically with Unito's 2-way integration. It's a low-code solution, so you don't need to write script, but you can. I put together this set of field mappings in about 5 minutes:
