‎08-28-2025 06:52 AM
Hi Community,
I have a scenario where certain business managers (non-ITIL users) need the ability to view incidents in ServiceNow without being granted the ITIL role. These users:
- Do not need to create, update, or assign incidents.
- Only require read-only access to specific types of incidents (based on conditions such as assignment group, category, or other filters).
- Should be able to view the form details and work notes but not perform any actions.
I’d like to achieve this without modifying the standard incident ACLs tied to ITIL.
I also noticed that:
- I don’t see any SNC-internal role available.
- The sn_read_only role is also not helpful in this case.
Questions:
- What is the recommended way to grant incident read-only access to a custom role (non-ITIL)?
- Should I clone the incident ACLs and adjust conditions for the new role?
- Is there a better approach (e.g., data policies, UI view restrictions, or reporting-only access) for such use cases?
Appreciate any guidance or best practices from those who’ve implemented a similar requirement.
‎08-28-2025 07:18 AM
‎08-28-2025 07:23 AM
In this case use OOTB role as shown:
‎08-28-2025 07:35 AM
I dont see any role like
sn_incident_read
sn_incident_write
in our instance
‎08-28-2025 07:53 AM
Hi @Kumar54 ,
You should install ITSM roles -plugin to instance to see thse roles.
Nikhil Bajaj
‎08-28-2025 07:56 AM
Hi @Kumar54
It must be available OOTB. If not, as recommended by @Nikhil Bajaj9 , install the ITSM role plugins.
‎08-28-2025 02:43 PM
