07-07-2025 07:45 AM
Hello Developers,
I have a requirement where an RITM is created from an Incident using the 'Relates Search Results' functionality. From there, users can search for a Service Requester and click on ‘Order’, which redirects them to the catalog item using the servicecatalog_cat_item_view form.
In this context, I’d like to auto-populate the field what_is_source_of_exception_requirement on the catalog item with the incident number (i.e., the parent record of the RITM).
Here’s the URL being used:
com.glideapp.servicecatalog_cat_item_view.do?v=1&sysparm_id=8ea574d297a62290cbf4b976f053af12&sysparm_view=catalog_default&sysparm_parent_table=incident&sysparm_parent_sys_id=096777069726ee50cbf4b976f053af57
I attempted this via a client script, but it doesn’t seem to work—likely because client scripts can’t access server-side data like the incident number directly using GlideRecord.
Could you please advise if this can be achieved, and if so, what would be the recommended approach?
Thank you!
07-08-2025 12:37 AM
I already informed to use GlideAjax and query INC table and get number
Another way is to use GlideRecord with callback
Something like this
function onLoad() {
var gUrl = new GlideURL();
gUrl.setFromCurrent();
var incSysId = gUrl.getParam("sysparm_parent_sys_id");
gr.addQuery('sys_id', incSysId);
gr.query(checkRecord);
function checkRecord(gr) {
if (gr.next()) {
g_form.setValue('what_is_source_of_exception_requirement', gr.number);
07-08-2025 12:48 AM
GlideRecord with callback should be fine.
Another way I already told to use GlideAjax
I believe I have answered your question.
