OLA not triggered
Options
08-13-2023 11:57 PM
Hi Help,
Good day. I have a requirement to get a list of incidents for which the OLAs (both response or resolution) are not triggered. How to achieve this. On which table should I query.
If it is the incident table, how should I query?
Thanks in Advance
Options
08-14-2023 12:31 AM
hello @Bh2 ,
you can create a normal report on incident table and type as bar graph and call a script include like below to get the incident sys_ids
Script include:
var getSlaIncidents = Class.create();
getSlaIncidents.prototype = {
initialize: function() {
getincidents:function()
var arr=[];
gr.addActiveQuery();
while(gr.next())
var no_sla = new GlideRecord('task_sla');
no_sla.addQuery('task',gr.sys_id);
no_sla.query();
if(!no_sla.next())
arr.push(gr.sys_id.toString());
return "sys_idIN"+arr.toString();
type: 'getSlaIncidents'
SCRIPT INCLUDE NAME: getSlaIncidents
Hope this helps
Mark my answer correct if this helps you
