priority of client script and ui policy
ROger1143
Mega Expert
ui policy        setvisible=true
client script   setVisible=false
Clien script over rides ui policy
but for  setmandatory and set readonly ui policy over rides client script
so why in first case ,client script over rides ui policy
Ajay_Chavan
Why Client Script Overrides UI Policy for setVisible:
Timing: Client scripts run after UI policies
Last Action Wins: Whatever executes last determines final visibility
No Form Validation: Visibility is just DOM manipulation
Why UI Policy Overrides Client Script for setMandatory/setReadonly:
Form Engine Control: UI Policy engine has higher precedence for form validation
Built-in Protection: ServiceNow protects mandatory/readonly settings at form level
Validation Priority: Form validation rules override client-side changes
Execution Order:
1. Form Loads
2. UI Policies Execute
3. Client Scripts Execute (onLoad)
4. Field Changes → UI Policies → Client Scripts (onChange)
Summary:
setVisible: Pure DOM manipulation → Last script wins (Client Script)
setMandatory/setReadonly: Form validation → UI Policy precedence (System protection)
Key Point: ServiceNow treats visibility as presentation but mandatory/readonly as form validation rules with different priority systems.
Glad I could help! If this solved your issue, please mark it as ✅ Helpful and ✅ Accept as Solution so others can benefit too.*****Chavan A.P. | Technical Architect | Certified Professional*****
9 REPLIES 9
ok
@ROger1143
Did you get a chance to review this ?
If my response helped to answer your query, please mark it helpful & accept the solution.
Bhuvan
Rafael Batistot
Mega Patron
hi @ROger1143
Visibility → Client Script wins (because it manipulates the DOM directly).
Mandatory/Read-only → UI Policy wins (because ServiceNow enforces them after scripts to ensure compliance with rules).
If this response was helpful, please mark it as Helpful and, if applicable, as Correct.
This helps other users find accurate and useful information more easily
Ok, Thank You
 Warm regards,
Aditya HUblikar
Ajay_Chavan
Execution Order:
1. Form Loads
Summary:
