Reference Qualifier issues
jonathangilbert
Hi All
Can someone help me with a reference qualifier on a Catalog item
I have the first variable on the form called "Colleagues Store Location", which is referencing the location table.
I want the 2nd variable called "Name of colleague" which references a custom table called "employee data". This table also includes a field called u_location, which references the location table.
What I am trying to do is for the 2nd variable to only display the employees that have the same location on their employee record (u_location) that has been selected in the first variable
So for example, if the Colleagues Store Location is set as "Birmingham", I only want the 2nd variable "Name of Colleague" to only display users that have "Birmingham" as the location on the their record
This is what I had as the ref qualifier on the 2nd variable, but it just displays everything
u_location=javascript:current.variables.colleagues_store_location
Rakesh_M
Hi @jonathangilbert ,
Use advance reference and give reference qualifier as
javascript: 'u_location=' + current.variables.colleagues_store_location
Rakesh
@jonathangilbert -
  • The syntax is off.
  • In catalog items, reference qualifiers need to return a query string or a function that evaluates the variable value.
  • Simply pointing to current.variables doesn’t filter correctly.
