03-31-2025 04:48 PM - edited 03-31-2025 11:03 PM
Can anyone help me understand why this simple script is causing the info message to be displayed twice only within SOW?
I should add there is no other onChange client scripts that are associated with this field. Checking or unchecking isolated script appears to make no difference once so ever.
04-01-2025 01:46 PM
From our SOW admin:
I went and duplicated the new record page and checked the whole duplication issue after and everything seems to be working just fine now.
03-31-2025 08:48 PM
Hmm that's the only thing which might cause this.
I used script from @Vishal Jaswal and it worked fine as well in SOW
03-31-2025 08:50 PM
works fine in my PDI as well and what has me wanting to pull my hair out.
This makes zero sense but for this script this seems to work:
if (isLoading || isTemplate) {
// Define the field name explicitly
var fieldName = 'description'; // Replace 'your_field_name' with the actual field name
// Add a delay of 5 seconds before executing further actions
setTimeout(function() {
// Check if the field is still populated
if (g_form.getValue(fieldName)) {
if (newValue === 'email') {
console.log('Testing');
g_form.addInfoMessage('Testing');
g_form.setValue('description', 'test');
g_form.clearMessages();
}, 5000); // 5000 milliseconds = 5 seconds
I have tried to update my script following this format but not successful thus far but leads me further into there is a loop or something causing it to run twice.
03-31-2025 09:04 PM
any other client script is setting channel and causing the script to trigger and hence show the message?
I don't think domain separation should have any say in this
03-31-2025 09:07 PM - edited 03-31-2025 11:13 PM
Why I created this script on the Channel field and not the State field as I thought that might be the issue. There is no other client script on this field that I can find. Seems to be any client script running twice within SOW only.
03-31-2025 09:34 PM
Something is causing this definitely.
