Field Shows on Employee Portal but Not In SOW or Platform View
JamesNowe
Giga Expert
I have Create Incident setup in our Instance. We modified it to add new Subcategories which is working fine. The ask was to have an additional field called End User/Persona Type (For IT Use Only) which I setup with a Select box. The field is only to be visible to itil users. The field shows on the Create Incident Request on the Employee Portal. When I go to the incident in either SOW or Platform view the field does not show up. I've done similar things before with Request and never had an issue. I'm not sure what I am missing.
I can use the dropdown and select one of the option and submit the incident without issue.
Any suggestions would be appreciated!
2 ACCEPTED SOLUTIONS
@JamesNowe
seems variable editor is missing in your form as per screenshot.
Add it in default view and Service Operations Workspace view and you will start seeing variable editor
Please check if the variable editor is already created on incident table in the instance by navigating to System UI > Formatters.
If it is exists in the table, then go to incident table
Right click on form header and select Configure > Form Layout
Using the slushbucket, bring the variable editor to the selected section and Save
Do this for Default and SOW View
That worked! Thanks for the help!
shyamkumar VK
Mega Patron
@JamesNowe
when you say platform or SOW
your asking that it’s not visible on variable editor or on the Form view
if its on the Form view you should have the field created and added to Default view and Servicenow operation workspace(sow) view to Make the fields visible
shyam
