How can i Modify Compose panel in SOW
Yd0801
I want to customize compse panel in SOW
I want to add field there but not able to find a way to edit compose section
Ankur Bawiskar
@Yd0801
which field you want to add?
OOTB it's meant to show only Journal fields such as Comments/Work notes
This helps agents to quickly add notes/comments to record.
I don't think it's feasible to add any extra field
You should inform customer about this platform limitation and feature and avoid any such requirement.
@Ankur Bawiskar ,
i have to add watchlist section in the middle panel,
customer has provided below image to complete the requirement. Do you have idea how to achieve this?
