How to Show popup When Button click on SOW
SS1510
Hello ,
I have a requirement to show existing UI action on SOW on incident record. In the UI action there is a popup when button click to select, In ui action i click on the workspace form button then it is visible on the workspace, but when i click the button the popup is not showing, does anyone has any idea how to achieve this.
@SS1510
another way is don't use UI page and show reference field on modal itself and then update
see this
How to use g_modal from an UI Action for Agent Workspace?  -> response from Amitoj
💡 If my response helped, please mark it as correct and close the thread 🔒— this helps future readers find the solution faster! 🙏
9 REPLIES 9
@SS1510
what that UI page is rendering?
are you asking user to enter something or select something and then updating the record?
@Ankur Bawiskar
The UI Page renders a simple modal where the user selects a Business Service (reference field) and clicks Submit. And after that record gets updated
@SS1510
so what's not working?
UI page is not getting rendered?
UI page is rendered and user is able to select but unable to update?
share your UI page screenshots, scripts etc
@SS1510
see this
Tanushree Maiti
Hi @SS1510
You can do it by following it.
    Refer: Solved: Re: UI Action VS Declarative Action - ServiceNow Community
                    Solved: Re: Resolve button popup - ServiceNow Community
Tanushree Maiti
