acabo de crear una instancia y no tengo el usuario ni la contraseña, como soluciono esto?
manuellozano
Acabo de crear una instancia nueva y no tengo el usuario ni la contraseña, como soluciono esto, o donde puedo solicitarla?
Pradeep Sharma
Hi manuel,
Username will be admin.
Under the My Instance page, use the "Action" button and select the "Reset admin password" action. After confirming that you wish to proceed, the developer site resets the admin password and provides you with a temporary password in green text that you should copy. Navigate to your instance by clicking the "URL" text in the green box or typing the URL in a new tab or window. You are prompted on your personal developer instance to set a new password. Use the temporary password for the current password and provide a new password twice.
