How to activate Discovery Tool plugin
jaustin1
How do I activate the Discovery Tool plugin for my developer instance? I can't locate it in the list of other plugins available.
thank you,
Joshua
Midhun1
Giga Guru
Go to your developer instance
Drag your mouse over Manage---you will see "instance" like above.
Click on that instance and you will see
click on action-->
Then click on Active plugin then you you will get the screen shot of previous reply
and active the discovery plugin
Midhun1
Giga Guru
click on action-->
