04-18-2024 12:31 AM
Hallo
my instance has not been able to wake up for almost a week now. Refreshing doesn't help at all.
This is the message being displayed:
"Developer Instance is undergoing unscheduled maintenance. Get Notified when your PDI is available."
any help will be much appreciated. Thanks
Best regards
04-18-2024 01:39 AM
Hi @BonifaceOchieng ,
As you might know, there is no support available from ServiceNow in relation to PDIs, hence you're limited to two options:
- Wait, it should come online after some time
- If you get tired of waiting, release the instance and request a fresh installation. Note, that anything that hasn't been backed up will be lost.
Best regards
Anders
Best regards
Anders
Rising star 2024
MVP 2025
04-18-2024 01:39 AM
Best regards
Anders
Best regards
Anders
Rising star 2024
MVP 2025
04-18-2024 01:45 AM
Hallo @AndersBGS ,
Thanks for your reply. I am indeed aware that there is no support for PDI s and only asked because it was suggested as i was releasing the instance. I think i will just release it.
Best regards
