Workflow is not loading.
sonu_patidar
Kilo Explorer
I am not sure why my instance is not loading a workflow on the drawing canvas.
When I open the workflow editor and just choose any workflow from side pane, it is showing as "Loading" but nothing is happening.Untitled.png
Nothing is happening after that.
13 REPLIES 13
Thanks so much Brendan for this tip as we had the same issue and your solution worked for us.
Thanks for the help Brendan. I have faced the similar issue & your's answer helps
You saved me. Your response should be marked as correct.
Thanks a lot! Great help!
