BMC Control-M and Event Management integration
dezire01
Did anyone integrate BMC Control-M with the Event Management module in ServiceNow? Other than email, and SNMP what are the recommended approaches to create this integration with Event Management? I understand there is another option to develop a custom connector but we do not want to take that path and that would be our last resort. Any other solution?
Thanks!
Hii dezire01,
Any luck.? We fall under same situation
prawagh
Hi @dezire01,
Just wanted to check on the setup you are working on.
Can you help with steps if you have configured event integration Control M to ServiceNow.
danielc4
have you resolved this? Check this controlm_toolset/sendAlarmToScript/Python/ServiceNow at main · dcompane/controlm_toolset
Go up and there is a bash script also.
They need to run in the Control-M server.
