Discovery Pattern Failure - Identification Engine: Discovery using patterns failed due to lack of existence of the main CI type in the results.
Arathi B Raj
Mega Contributor
Hello  Everyone
While trying to discover windows servers, Discovery Pattern is failing with the following error.
find_real_file.pngIs there anyone who would know how to resolve this or what is the cause of this happening.
Rahul Priyadars
Tera Sage
see if these helps u
https://support.servicenow.com/kb?id=kb_article_view&sysparm_article=KB1096246
https://community.servicenow.com/community?id=community_question&sys_id=7e893925db283700fece0b55ca96197e
is this happening for all windows server?
Can you try doing a quick discovery with 1 IP - Is this error is still coming ?
RP
Deepika N1
I'm facing the same issue for cloud discovery, Azure - Hardware Type (LP) pattern is getting failed with this error. I have tried this in debug mode where its executing successfully.
Any idea how to resolve this or what is the cause of this issue.
Deepika
Nattaphol Ubols
I had the same issue and it was to do with Serverless Execution Pattern url missing "https://"
