How IRE engine works during Transform maps
Anshu_Anand_
Dear All,
Can anyone explain how IRE works during transform maps or does it not.
we have altiris intigration which populates cmdb tables by transform map and also servicenow discovery
populates it.
So we have lot of duplicates. Does transform map in integrations skip Identification rules?
Anshu
Thanks for that great piece of information!!
For step 1 above - i am planning to use JDBC data source type of SQL Server
For step 2 - Which Altiris API document are you referring to (could you paste the link here)? In my case - the Altiris system is on On-Premise and there does not seems to be any REST API endpoint for it to connect to.
Other steps are good. thanks
Priyanka
correction in my previous comment, i also used JDBC connection.
Here is the screenshot of 1 of the datasources configuration
use sql query to fetch data and next steps are same.
Hope this is helpful. if you have access to the database , then you can create your own sql query to fetch the records
