11-20-2014 05:45 AM
For change management module we are using OOTB UI macro 'approval_summarizer_default' for showing fields in My approvals.
Now I want to add some more fields to that My approvals for that where I have to change in UI macro?
Below is the OOTB code for that
<j:jelly trim="true" xmlns:j="jelly:core" xmlns:g="glide" xmlns:j2="null" xmlns:g2="null">
<g:evaluate var="jvar_has_source" >
var flag = !${ref}.sysapproval.nil() || !${ref}.source_table.nil();
flag;
</g:evaluate>
<j:if test="${jvar_has_source}">
<g:evaluate var="jvar_ni" expression="
var gr = null;
if ( !${ref}.source_table.nil()) {
gr = new GlideRecord(${ref}.source_table);
gr.get( ${ref}.document_id);
gr = new GlideRecord('task');
gr.get(${ref}.sysapproval);
<g:evaluate>
g_approval_form_request = true; // this global is checked in ACLs
</g:evaluate>
<g:evaluate var="jvar_my_form">
var gc = new GlideController();
var p = new GlidePopup(gc, "${gr.sys_class_name}");
p.putParameter("sys_id", "${gr.sys_id}");
p.putParameter("sysparm_view", "approval");
var rp = p.getRenderProperties();
rp.setSmallCaption(true);
var s = p.getPopup();
s;
</g:evaluate>
<tr id="approval_summary_row">
<td width="100%" colspan="2">
<j2:if test="${gs.getProperty('glide.security.use_csrf_token')}" >
<input type="HIDDEN" name="sysparm_ck" value="$[gs.getSessionToken()]"/>
</j2:if>
<div id="approval_summary" style="padding-top:8px;display:none;">
<div class="caption" style="padding:4px;">${gs.getMessage('Summary of Item being approved')}</div>
<div style="padding-left:2px;"><g:no_escape>${jvar_my_form}</g:no_escape></div>
</div>
</td>
</tr>
<g:evaluate>
delete g_approval_form_request; // removes the global
</g:evaluate>
<script>
addRenderEvent(moveSummaryForm);
function moveSummaryForm() {
var e = $("approval_summary");
var form = $("sysapproval_approver.do");
var formParent = form.parentNode;
formParent.appendChild(e);
e.show();
</script>
</j:if>
</j:jelly>
See the below screen shot
Here I want to add and remove some fields.For that where I have to change in that UI macro
Service Mapping
11-30-2014 06:44 AM
You can use an if statement in the g:evaluate block where the p.putParameter("sysparm_view", "approval"); line is. Just use the gr object to check the user selected value on the change request and pass in the view name for approval.
11-28-2014 08:54 AM
Any idea on this?
11-28-2014 11:18 AM
The view just determines what fields you see when you look at the record, so an approval wouldn't necessarily be tied to a specific view. You would need to determine which view you want to show in the macro (probably using some attribute on the record or from the logged in user), and then call either one of your change views based on that.
11-28-2014 06:04 PM
Hi Brad,
I want to call both the views in that ui macro based on the option selected by the user.How can I write that condition in UI macro?
11-30-2014 06:44 AM
12-03-2014 05:29 AM
Excellent idea it is working
