11-20-2014 05:45 AM
For change management module we are using OOTB UI macro 'approval_summarizer_default' for showing fields in My approvals.
Now I want to add some more fields to that My approvals for that where I have to change in UI macro?
Below is the OOTB code for that
<j:jelly trim="true" xmlns:j="jelly:core" xmlns:g="glide" xmlns:j2="null" xmlns:g2="null">
<g:evaluate var="jvar_has_source" >
var flag = !${ref}.sysapproval.nil() || !${ref}.source_table.nil();
flag;
</g:evaluate>
<j:if test="${jvar_has_source}">
<g:evaluate var="jvar_ni" expression="
var gr = null;
if ( !${ref}.source_table.nil()) {
gr = new GlideRecord(${ref}.source_table);
gr.get( ${ref}.document_id);
gr = new GlideRecord('task');
gr.get(${ref}.sysapproval);
<g:evaluate>
g_approval_form_request = true; // this global is checked in ACLs
</g:evaluate>
<g:evaluate var="jvar_my_form">
var gc = new GlideController();
var p = new GlidePopup(gc, "${gr.sys_class_name}");
p.putParameter("sys_id", "${gr.sys_id}");
p.putParameter("sysparm_view", "approval");
var rp = p.getRenderProperties();
rp.setSmallCaption(true);
var s = p.getPopup();
s;
</g:evaluate>
<tr id="approval_summary_row">
<td width="100%" colspan="2">
<j2:if test="${gs.getProperty('glide.security.use_csrf_token')}" >
<input type="HIDDEN" name="sysparm_ck" value="$[gs.getSessionToken()]"/>
</j2:if>
<div id="approval_summary" style="padding-top:8px;display:none;">
<div class="caption" style="padding:4px;">${gs.getMessage('Summary of Item being approved')}</div>
<div style="padding-left:2px;"><g:no_escape>${jvar_my_form}</g:no_escape></div>
</div>
</td>
</tr>
<g:evaluate>
delete g_approval_form_request; // removes the global
</g:evaluate>
<script>
addRenderEvent(moveSummaryForm);
function moveSummaryForm() {
var e = $("approval_summary");
var form = $("sysapproval_approver.do");
var formParent = form.parentNode;
formParent.appendChild(e);
e.show();
</script>
</j:if>
</j:jelly>
See the below screen shot
Here I want to add and remove some fields.For that where I have to change in that UI macro
Service Mapping
11-30-2014 06:44 AM
You can use an if statement in the g:evaluate block where the p.putParameter("sysparm_view", "approval"); line is. Just use the gr object to check the user selected value on the change request and pass in the view name for approval.
12-03-2014 05:36 AM
12-03-2014 10:22 PM
Any one have idea on this?
12-04-2014 06:49 AM
In order to change that view you need to edit the sys_popup view for the change table. Unfortunately this is a global setting and you can't use multiple views.
http://wiki.servicenow.com/index.php?title=Customizing_the_Reference_Icon#Fields_Displayed
12-04-2014 06:53 AM
Okay got it ...we can't do this for different views
