How to send event from Kibana to Snow using ServiceNow ITOM Connector
ninhnguyen
Hi Snow team!
I am working on integrating the our Kibana to send metrics Snow using ServiceNow ITOM Connector.
However when i tried to test sending events from Kibana, it requires the Severity params, I couldn't find anyplace to set this up.
Could you gimme some advise?
Much appreciate!!!
Hi @ninhnguyen
you can try out Event Management on your PDI.
The request process for PDIs is simplified and possible after logging in at developer.servicenow.com:
Maik
13 REPLIES 13
ninhnguyen
Thanks @Maik Skoddow and @Rahul Priyadars so much for you help!!!
Maik Skoddow
Glad to help!
ninhnguyen
Just FYI @Maik Skoddow @Rahul Priyadars
it seems the ServiceNow ITOM connector in Kibana has a bug with Severity field. There are some person has same issue with me. that's why i was bothering you guys for last few days. Sorry about that!!!
https://github.com/elastic/elasticsearch/issues/99420
Hello Ninhnguyen - did you ever find a resolution to the bug? I'm stuck with the same issue right now and any leads on how you were able to resolve the bug would be greatly appreciated. Thank you!
